axle bearings
deeman7777
I have an older style integral hub type trailer wheel for an Elgin / Sears boat trailer.
These are hard to find and I found a guy looking to get of 2 of these.
The problem is my axle is 3/4" and the hubs/axle opening on these are 1". The guy said I could get different bearings and it would work.
I only plan to use one of these for the sapre.
Does this sound right? Can the "right" bearing make this wheel work?
Thanks!
Mike
Silvertip
Honorary Supreme Mariner
Re: axle bearings
Just one measurement on a bearing doesn't usually allow conversion. If the inner diameter is 3/4 inch yours, the outer diameter of the race it must run in may also be smaller. If you find 3/4 inch bearings that runs in the same race as a one inch bearing then yes it will work. Otherwise not.
deeman7777
Re: axle bearings
Thanks for the reply.
After re-reading the post, I see I was not very descriptive of my issue.
My current wheels are made for a 3/4" axle. The sellers wheels are made for a 1" axle. He suggested getting different bearings to make the the 1" wheels work on my trailer.
Hope this helps.
