Tracker175
- Jun 8, 2009
- 4
I have a 08 Tracker equipped with a Mercury 115 Optimax. Yesterday out on the water it was idling extremely rough and would only wrap out at 3000 rpm pushing 20mph. It smelled of fuel in the boat. All of this is new as I had the boat out the day before and it ran fine. I checked for water in the gas and their is none. Any help or ideas?
I pulled the spark plugs and found that the top 2 had an oil build-up and the bottom was clean but had a fuel residual on it. I replaced the spark plugs and took the boat out today to find no improvement. It idled rough and ran horrible acting as if not all 3 cylinders were firing. When I got home I pulled the plugs and found the same about each plug I mentioned above. I called my service provider and he said "never heard of that don't know what to tell you!" This engine has approximately 10 hours on it.
