What size closed rivets for aluminum boat
Hello, I have a 16' starecraft boat that I need to repair 6 rivets along the keel. The rivets broke when I hit a rather larger rock. The aluminum bent but is OK. Can anyone tell me what is the correct size rivet to use. I assume a 3/16 size hole will be made to take the old rivet out but how long should the rivet be? I assume I will need to fasten 3 pieces of aluminum together so the material might be .300 thick?? I'm not sure?? (keel, floor, support beam) all need to be riveted together? Also, can I use a hand held rivet gun? or do I need a more powerful gun.
I am new to riveting so any help is appreciated. Thanks!
