Hello
I am new to this forum and new to boating. I bought a 1983 Larson 21 cuddy with a 898 Mercruise. used only in fresh water.
The problem I have is the engine will overheat to 200 when at full throttle and about 160 at anything below full throttle.
The thing is that it does not always over heat at full throttle. Just the odd time.
I am looking for some help if anyone can give me a hand.
I have the repair manual and will repair mostly anything (execpt rebuild entire engine)
I gave the engine a new Manifold and riser on the starboard side and new bellow on the same side. could it be the port side needs a cleaning out?
I never took out the stat could this be the problem as well.
Again thanks
Again thanks
