Barry Splaine
- Jun 7, 2009
- 1
[/SIZE]
Took for maiden voyage approx 3 mi run, on return the water/temp gauge lit up and warning buzzer sounded. Put motor in neutral and checked for water exiting port....there was lots and it was cool. After shuting down engine and checking under cover....slight odour like electric wires burning...started engine again and proceeded approx 200 yds and same thing happened. Is there something else that could cause the warning indicator to react as it does appear to be getting water pumped thru the engine?
