VRO leak, I think I know the answer but...
AEROCOOK
Master Chief Petty Officer
My new to me 1987 Evinrude 90hp has a bad fuel leak at the back of the VRO pump. I have determined that the leak is coming from the pulse pin o ring for the "No oil flow" alarm. I noticed the leak when I was pumping the primer bulb and it is a severe leak, not just a little bit of seepage. Is this a common thing to fail with these pumps? Any chance of getting one of these o rings?
I should also mention that the previous owner took the pump apart so who knows, maybe a part is missing??
Any guidance would be greatly appreciated.
tashasdaddy
Re: VRO leak, I think I know the answer but...
go premix and replace with one of these. they were for the older 115's, and work off the pulse line, just make a bracket for it.
Part Number: 0385784
Description: FUEL PUMP AY
Pack Qty: 1
Dimensions: 3.50 x 3.50 x 2.25 (in)
Weight: 0.44 lbs
Equivalent Parts: 0395712,0398385,0433390,0438559
AEROCOOK
Pack Qty: 1
Weight: 0.44 lbs
Bingo! Thats thats the answer I thought I knew.
I have another small problem with my warning horn but thats another topic so I will start a new thread.
