I have a 1990 boat with a omc drive.
My gimbal as a hole in it and leaking what i need to know is if all the gimbals are the same or not been told thay are and that that are not.
Is the chevy and ford the same i have a 3.0L 140hp with a 5.0 lower unit this came from lazer boat factory this way.
will the ford gimbal work on the chevy i only need the part that the outdrive hooks too whats diff I WAS TOLD THEY ARE DIFF WERE THE Y PIPE OR PIPE BOLTS UP
Thanks
Thanks
