  #1
Old June 30th, 2009, 12:04 PM
fishnjunkie fishnjunkie is offline
Default drive shaft on 1958 18 hp evinrude
I was curious as to how comparable the johnson drive shafts and the evinrude shafts were for that year. The Johnson 61? drive shaft, that i have access to, is 4 splinned at the top and 11 at the bottom and measures 26". would this drive shaft work in my 58 rude? model 15024? thanks.
  #2
Old June 30th, 2009, 12:25 PM
wilde1j wilde1j is offline
Default Re: drive shaft on 1958 18 hp evinrude
Evinrude and Johnson for most years and models are the same except for the color and motor housing.
__________________
Jim
  #3
Old June 30th, 2009, 12:33 PM
so, by having a shop manual it would have said, the johnson and evinrude models are identical, just buy what fits? just not wanting to spend $250 on a drive shaft if i can get one for $25.
  #4
Old June 30th, 2009, 12:41 PM
BRP's on-line parts lists only go back to 1968, so I would suggest checking with an old time dealer, who will have paper PL's back further, to be certain. Most likely, J and E are identical mechanically for your model in a given year. Not sure about other years, however.
What is the spline arrangement on your existing drive shaft?
__________________
Jim
  #5
Old June 30th, 2009, 02:41 PM
jbjennings's Avatar
jbjennings jbjennings is offline
johnson and evinrude driveshafts are the same for any given year. the only difference in the 50's and 60's john/evin are the bosses on the powerhead for the cowl mounts and stuff that pertains to the cowls being different. The main part of the carbs. engine internals and midsections down are the same.
I don't believe that the drive shaft would interchange from a '61 to '58. I know the gears are cut different from '61. I'd wait for F-R for sure. I know they are both 4 at the top, both 26 inches, but I'm thinking the splines at the bottom may be different. IF F-R doesn't answer by this evening, I'll go look at mine and see for sure.
JBJ
  #6
Old June 30th, 2009, 04:13 PM
R.Johnson R.Johnson is offline
That driveshaft is the same well into the 70's. I have a 75, 25HP gearcase on my 57, 18HP. It bolted right on with no problems.
  #7
Old June 30th, 2009, 05:13 PM
tmcalavy tmcalavy is offline
Match the splines top and bottom and the length...should be pretty interchangeable.
  #8
Old June 30th, 2009, 06:00 PM
If you have to order one, simply go by the lengh of your engine.
  #9
Old July 7th, 2009, 12:25 PM
thanks y'all for all the responses. gonna take down tonight and get some exact measurements, and i'm crossing fingers that the one coming out is the same as the one i can get. thanks again everyone. will post with the outcome.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1958 18 hp evinrude shifting problem fishnjunkie Johnson & Evinrude Outboards 12 May 12th, 2009 12:29 PM
1969 Evinrude 18 HP Fastwin Cracked Drive Shaft PICS Lostuzer Johnson & Evinrude Outboards 7 January 30th, 2009 03:38 PM
1971 18 HP Evinrude - need drive shaft nellis Johnson & Evinrude Outboards 2 December 25th, 2008 09:40 PM
1958 evinrude 18 hp back fires thru exhaust Fastwin18 Johnson & Evinrude Outboards 14 August 1st, 2007 03:15 PM
1958 Evinrude 18 HP Fastwin jgriffith@taylor-dunn.com Johnson & Evinrude Outboards 7 June 6th, 2007 09:12 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
