Re: Yamaha Throttle Remote Control
Ok, after a sea test, here was the deal, when you pop off the throttle cover there are basically 3 adjustment screws, the 2 to the front and rear of the throttle lever adjust how much pressure you need to place for the throttle to go into forward or reverse. The one I was looking for is at the front / base of the controller 1/2 turn clockwise eliminated my loose throttle problems.. Hope this helps someone.. thanks
