  #1
Old June 30th, 2009, 04:35 AM
dbdsaltydog dbdsaltydog is offline
Smile Evinrude 1990 120HP stalling when warm
My Engine seems like it is starving for gas after it has run for about 20 minutes. I noticed the bulb in the fuel line was caving in so i replaced that and the inline filter but i still have the problem w/out the bulb caving. Is this a carb issue or over heating issue. The buzzer in the dash is staying on with or without the engine running...thank you!!!!
  #2
Old June 30th, 2009, 06:04 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Evinrude 1990 120HP stalling when warm
caving bulb, is a 99% sign that the fuel tank vent is closed or clogged. fuel restriction issue. pump cannot suck fuel out of a vacuum.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old July 10th, 2009, 08:15 PM
Quote:
thank you tashasdaddy for your reply! I had already replaced the vent at then end of the fuel line vent hose. when i took the old one off it appeared to be more than what i replaced it with. should there be more than just a vent on that hose?
  #4
Old July 11th, 2009, 05:06 AM
can you blow air thru the vent line? you also could have a clogged pickup in the fuel tank. what ever the problem it is before the primer bulb.
__________________
FLORIDA GATORS
TEBOW Country
  #5
Old July 12th, 2009, 11:05 AM
115johnson78 115johnson78 is offline
Smile Re: Evinrude 1990 120HP stalling when warm
I had the same problem with my boat. If it is an built in tank, you might want to check the anti siphon to see if it is getting stuck.
  #6
Old July 15th, 2009, 08:42 PM
Quote:
thank you 115johnson78! this is my first ob motor and it is a built in tank. i replaced the vent and i believe the old one included the anti siphon??? would it not run properly without the anti siphon???
  #7
Old July 15th, 2009, 09:22 PM
the anti siphon is located in fuel tank sender. in between there and the motor. mine runs just fine. it is use so that a hose pops loose the fuel stops. it is for saftey. you can remove and if it solves prob. the replace with a new one. your welcome.
  #8
Old July 16th, 2009, 07:20 AM
thank you tashas daddy! not sure if i can blow air through the line but i replaced the old vent on the vent line with a new one and i believe the old one was an anti siphon vent. the one i replaced it with does not. do you think that could create the problem?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Some questions about 1990 120HP force Netjunky Force & Chrysler Outboards 18 April 23rd, 2009 11:59 PM
1990 evinrude 120hp wont stay running(vro) patric hunt Johnson & Evinrude Outboards 5 November 23rd, 2008 01:03 PM
1990 force 120hp Dan Mathison Force & Chrysler Outboards 1 August 10th, 2003 07:00 PM
1990 FORCE 120HP bulldogs Force & Chrysler Outboards 3 August 18th, 2001 12:36 PM
1977 85 hp Evinrude versus 1990 120Hp ridiver Johnson & Evinrude Outboards 2 July 18th, 2001 11:51 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
