Re: 1987 45hp mariner charging issues
It sounds like you're getting plenty of AC voltage out of the stator, even at idle. If DC output does not rise when the motor is throttled above idle, the rectifier is shot. You won't get much DC output at idle, however, so if you were trolling for a long time with a bunch of electronic gear going, it'll discharge the battery. The stator is only rated for around 10 amps charging, pretty nominal in any case. And that's at speed, not idling.
You might try picking up one of those El-Cheapo Radio Shack 25-amp-rated bridge rectifiers and just temporarily wiring it into the circuit to see if there's any change from your motor's rectifier. Under $5 and would actually work well enough as either a temporary or permanent replacement.
Just remember that the Rad Shack rectifier has to have its Negative terminal separately grounded, not thru the case as is the stock Merc rectifier.
HTH............ed
