  #1
Old June 29th, 2009, 04:03 PM
matt246 matt246 is offline
Unhappy mercury water pump (question)
hi there i have a 65hp mercury and it isnt pumping water and after pulling apart the water pump and looking at some exploded views of the same outboard online i realised that there were 2 gaskets missing so the way that it is in the picture is: gasket then the wearplate (also is that the metal plate gasket??)and then another gasket so is it ok to put liquid gasket and then the wearplate and then some more liquid gasket
  #2
Old June 29th, 2009, 04:41 PM
Lion hunter's Avatar
Lion hunter Lion hunter is offline
Master Chief Petty Officer
Default Re: mercury water pump (question)
I wouldn't use liquid gasket any where. Get the right gasket. It doesn't take much to plug a water system and liquid sealer will do it for sure. I would also doubt that the mating parts are machined to good enogh tolerances that liquid gasket would seal it by itself. I have only ever seen and used one type of liquid gasket that I would use on anything, it's red and made by caterpillar. But, it's way more expensive than those small gaskets that you will need.
  #3
Old June 29th, 2009, 04:52 PM
hi thanks for the reply i have loctite liquid gasket which is ok but what you said about the surfaces not beeing that good for mating but i will be putting the liquid gasket on and then tightening the housing down on it and leave it to set overnight but thats just me and im not an expertdo you think it would be better to make gaskets out of gasket paper that i have because i cant find those gaskets anywhere and it would take a while to get to me as i live in the outer hebrides in scotland so do you think that will be ok
  #4
Old June 29th, 2009, 05:00 PM
j_martin j_martin is offline
Quote:
Do you want advise, or do you want some other newby to verify your dangerous plan?
If you can't get the gaskets, your best second (poor) choice is to make them out of gasket paper.
Do not use liquid gasket makers in this system except where it is specified, and then only the type specified. If a blob escapes, and gets into one of the small internal ports in the engine, you can see some unusual, and expensive symptoms.
hope it helps
John
  #5
Old June 29th, 2009, 05:11 PM
hi there thanks alot much appreciated i know nothing about water pumps in outboards more of an engine man il do that tomorrow
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1978 Mercury 402 Water pump question mrcorrao Mercury & Mariner Outboards 3 July 13th, 2009 07:15 AM
1998 Gamefisher by Mercury - Water pump question tawd77 Mercury & Mariner Outboards 1 April 26th, 2009 12:52 AM
mercury water pump housing question roger777 Mercury & Mariner Outboards 5 April 19th, 2009 09:51 AM
mercury 140hp 2006 water pump question hkgboater Mercury & Mariner Outboards 1 June 3rd, 2008 01:48 PM
mercury 7.5 thunderbolt water pump question sledge Mercury & Mariner Outboards 4 August 29th, 2006 06:26 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
