  #1
Old June 29th, 2009, 03:41 PM
Boatonbrain Boatonbrain is offline
Default 1985 Evinrude 50 hp - Removal of Flywheel
I have a mid-80s Evinrude 50 hp tiller. I'd like to get at the battery recharger thing under the flywheel as I believe its not charging the starter battery anymore.
My problem is the nut on top of the flywheel does not budge. I jammed a screwdriver in between the starter gear and flywheel and put a cheater bar on a socket wrench and practically tip my boat over without getting the nut to move.
This can't be that hard. Any advice for getting a frozen nut to move? Thanks for any advice.
  #2
Old June 29th, 2009, 04:38 PM
Randyg123 Randyg123 is offline
Default Re: 1985 Evinrude 50 hp - Removal of Flywheel
It's a tight one but don't bust a nut!
I just popped mine off of a 1975 135HP. It took about 150 pounds of torque to loosen the nut on mine. Then I needed a harmonic balancer puller to pull the flywheel off of the shaft. When putting it all together the manual sets the torque at 100 ft-lbs.
There were a bunch of small holes driled into the top of my flywheel that I was able to put a bolt into and use the torque wrench socket, the bolt, and my engine hoist point combined to lock the flywheel and enable loosening of the bolt. One suggestion was to put it in gear and jam the prop with a 2x4.
Don't know if any of this advice applies to your motor. Hope this helps.
  #3
Old June 29th, 2009, 05:17 PM
InvaderScott InvaderScott is offline
if you have access, use an impact wrench. this will bust the nut loose without the chance of damaging either the ring gear, or anything in the gear train if you jam the prop to get the nut loose.
__________________
boat =
B reak
O ut
A nother
T housand
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
75' Evinrude 15 hp flywheel removal cphill13 Johnson & Evinrude Outboards 2 August 13th, 2008 04:16 PM
1956 Evinrude 5.5 HP Flywheel Removal dumpy Johnson & Evinrude Outboards 7 October 26th, 2007 11:02 PM
115 HP Evinrude Flywheel Removal pamlicobeach Johnson & Evinrude Outboards 10 August 28th, 2007 12:18 AM
82 50 HP Merc Flywheel Removal bigang Mercury & Mariner Outboards 4 June 27th, 2006 11:59 PM
Force 50 HP flywheel removal Grogan Force & Chrysler Outboards 4 September 21st, 2002 09:07 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
