Have a Johnson 6 (70s vintage?) that's always been a good motor. Last fall I could only get it to run on one cylinder, so this spring I started doing some testing. Bottom plug was a nice tan color and top plug was wet, so figured it was probably electrical. One of the main coils has a burn mark on the bottom and when I swapped the coils, the problem moved with the coil so I'm guessing it is the coil.
-any second guesses?
-how do I determine the year of the motor - the only two numbers I can find are on the frost plug and on the flywheel - there must be a model no/serial no somewhere.
- how hard is it to find a new coil for one of these motors? Should I replace both at the same time?
Thanks for all help.
