Re: Which harness is better for wakeboarding?
I'm confused - how is using the harness any different than the regular tow point on a boat? The harness hooks on to each of the tie-down points at the stern, allowing you to pull around an outboard engine, or the leg if your I/O doesn't have a center pull point or ski pylon.
__________________
1998 Moomba Outback, Indmar Blackhawk 350ci, 4bbl Holley carb
