sunbird 18
- May 19, 2008
- 78
2001 Yamaha 225 OX66 SX225TXRZ. When cruising at lets say 4000rpm and I use the trim switch on the controls, I notice a slight, 100-150, rpm reduction while operating the switch. The rpms return to 4000 after letting off the switch. I am just trying to understand what causes this. Hitting the trim switch causes my voltage to drop from about 14 to about 12. This reduction is affecting what......hmmmm... Injectors, ECU, Fuel Pump, ??
Is this normal?
What is causing the rpm reduction?
Is this normal?
