What drill and tap size for 1/4x 1/8" barb fitting
ba_50
It is being used for a vacuum port on a '57 Johnson. It is a Watts #17090192.
Thanks.
jonesg
Re: What drill and tap size for 1/4x 1/8" barb fitting
take the barb fitting to the hardware store and find the nut that threads onto the threaded part perfectly, thats your thread size, then just buy the drill/tap pair to suit.
Chris1956
I believe those fittings are NPT which is a tapered thread. You will need an NPT Tap.
