redone is correct on the wire thing - look at the top of your drive unit for these wires Lt.Blue with White stripe--------Trim up
Green with White stripe-----------Trim down
They will either be wrapped in a small bundle around or near the drive unit or as mentioned stapled under your dash.
Usually, if there was never a trim gauge installed the sending wires will all be at the transom. ( hopefully )
