  #1
Old June 28th, 2009, 01:37 PM
racer2525 racer2525 is offline
Default Pontoon Speed: Does this sound normal?
New (inexperienced) boater here with a new 26' Sanpan pontoon (model 2500 Limited, 2 tubes). Boat has a Yamaha F115 4-stroke, and WOT is around 5800rpm. Prop that came stock with motor is aluminum, 13" diameter, 15" pitch.
Max speed I get is only around 16.5mph with 3 people on board running WOT and max rpm's. I checked and there's no prop damage, etc. Motor runs fine. BUT....This seems really SLOW to me, and I read here where other pontoons seem to go much faster. I know that pontoons aren't designed for speed, but I'd like to at least run between 20-25mph. Is this realistic?
Any ideas or suggestions?
  #2
Old June 28th, 2009, 03:53 PM
Silvertip Silvertip is offline
Default Re: Pontoon Speed: Does this sound normal?
If you are using the standard speedometer for speed measurement, then that's part of the problem as they are terribly inaccurate (generally). Use a GPS to verify speed. 26 feet is a fairly large boat but a 115 should easily do 20 or better. I would blow your gates off with my 40 Suzy on an 18 footer so something is wrong. Is it possible one or both tubes have water in them? Is this a particularly heavy pontoon?
  #3
Old June 28th, 2009, 04:03 PM
Quote:
Thanks for the reply! I'm using the GPS on my boat for the speed (agree...the analog gauges are not good). The net boat weight (dry) is listed at 3062 lbs. The wet weight (with motor, fuel, etc) is listed at 3806 lbs. So...it is a heavy boat. It's a new boat I got in April, so doubt it has any holes for water to get in but guess you never know....new is not always perfect. How would I check that? Also, I guess I should contact the boat maufacturer to see what they say, or maybe Yamaha?
  #4
Old June 28th, 2009, 04:19 PM
18footcheetah 18footcheetah is offline
I'm getting 18 or so at WOT on a 24 foot bently with a 60 horse bigfoot merc so your definatly not proped right. Did you get it from a dealer?
  #5
Old June 28th, 2009, 07:34 PM
Quote:
Yes. I will contact the dealer, Yamaha, and Godfrey Marine (boat manufacturer) to see what they can tell me. I talked to two other guys that have pontoons (slightly smaller and probably less weight) and one told me he got 35mph. The other claimed to get 55mph (tri-toon with 200hp motor). Not sure I believe that, but I think I should be getting at least 20mph. The prop is also an aluminum Yamaha prop that came with the motor, so would think it might be OK. Will see. Thanks!
  #6
Old June 28th, 2009, 08:08 PM
Quote:
Sounds like dealer would be best bet..... I would belive the 55 mph claim I had one come out of a cove and pull away from me in my bass boat(18' Cheetah 115 Evinrude) I was doing 30 about 1/2 throttle I took my speed on up to about 45 and never did catch it lol prolly coulda went WOT and got him though.
  #7
Old June 28th, 2009, 09:14 PM
steelespike steelespike is offline
Looked at some similar setups Couldn't find as heavy or as big a 22' 3,300 115 evinrude 13" ss 29 mph.. 22,2680 15"ss 32.. 24,3,000 13"ss 25...
23,3,100 11 al. 23 mph. Don't know your ratio but a 15 seems big for a 26
Yet your turning 5,800 at only 16 either tach is set wrong or a lot of slip
maybe even venting a little. 13" diameter seems small.They talk about elephant ear props for pontoons. The Evinrude is running 13 3/4 and 14.
Of course the gear ratio may be different.
  #8
Old June 30th, 2009, 12:14 PM
fneely fneely is offline
well I have a similar setup. Same engine, yamaha 115 on a new 24' silvan mirage that weighs about 2600 lbs dry. my max speed so far has been 28mph .
  #9
Old July 6th, 2009, 09:30 AM
Thanks for this data....that's great info for me to compare. I seem to have a real heavy boat which I know will have an impact. I think Yamaha has a new prop designed for pontoons (14" diameter). Not sure what pitch to get but from what I've read, lower seems better for speed. Thanks for taking the time to pull this data! I appreciate it.
  #10
Old July 6th, 2009, 09:38 AM
Quote:
Wow...wish I could get that. Like someone said above, maybe I have some water in my toons. But I kinda checked and didn't find any drain plugs underneath? I'm checking with dealer this week. Thanks.
  #11
Old July 6th, 2009, 09:56 AM
rrhodes's Avatar
rrhodes rrhodes is offline
I am leaning on your tach not being setup correctly. I would think you should run in the low 20's
__________________
Rick
2008 JC Neptoon 25TT
115hp Honda 4-stroke
2007 Suburban LTZ
Lake Murray, SC
  #12
Old July 6th, 2009, 10:13 AM
Rancherlee Rancherlee is offline
I would guess your tach is off also OR you are venting horribly. A 15 pitch prop on a 2.15 ratio gear case going 16mph is close to a 60% slip, pontoons usually are around 20-30% depending on load. My guess would be venting. A 15 pitch prop is usually a smaller diameter NON pontoon design. 11-13 pitch props will usually be the correct "elephant ear" pontoon style prop in a 14" diameter for that motor. A 13 pitch prop might be worth trying or possibly lowering the motor a bolt hole or 2 if its not down all the way already. A 13 pitch prop in the normal 20-30% slip range would put you at 24-27.5mph if the motor has enough push to get you there.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Does this sound normal? (Wierd sound at full throttle) bhughes Johnson & Evinrude Outboards 6 May 7th, 2009 12:17 AM
How does this deal sound for a Pontoon txjeff Boat Topics and Questions (not engine topics) 21 May 22nd, 2008 08:08 PM
New to I/O's is this sound normal or should get out the toolbox Boomyal Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 July 4th, 2006 05:57 PM
At what temperature does a Yamaha's buzzer sound? What is normal running temp? patrolcarr Yamaha & Suzuki Outboards 1 June 15th, 2003 08:05 PM
Does this sound normal for a Force? kwk Force & Chrysler Outboards 2 August 20th, 2002 05:30 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
