HeadonaStick
- Jun 3, 2009
- 2
I just bought a trailer for a 1981 Thunderbird Formula. Since the trailer was not originally for this boat, all the parts don't fit.
As it sits, it has two sets of vertical bunks, each about 8 feet long. I want to replace the inner set (they sit directly on the trailer frame) and dispose of the outer set. At the same time I am adding three sets of keel rollers at the first cross member, at center hull, and under the bow section.
My questions are:
Sorry if these are obvious questions - I never trailered a boat before (we dropped our boats in the water for the summer and pulled them for the winter in my younger days) so I am lost. I read through the first ten pages of the forum and used the search function... if I committed a forum faux pas please go easy on me
I am also a bit pressed for time. The person I purchased the boat from needs it moved asap - this weekend! I just got word last night so now I'm in a panic.
Any help would be appreciated - Thanks!
My questions are:
- Is there enough support from a pair of paired 2x8x10 bunks and keel rollers
- If not, how do I get the bunks to fit the hull properly - it is easy to get one set to fit the hull, but the second is a little more difficult. Can I put a second set of bunks on with the boat loaded somehow?
- Does the top edge of the bunk need to be cut to match the angle of the hull? The Thunderbird is a deep "V" hull and it seems like the hull will rest on just the edge of the bunk.
