  #1
Old June 27th, 2009, 06:39 PM
keithet keithet is offline
Default Correct Prop for pontoon boat
Hello,
I have an 18' Voyager pontoon boat with a Yamaha 40 hp 4 stroke. I have a Yamaha 11 5/8 D by 11" pitch prop. Using a Yamaha marine mechanics tach (which agrees with mine) I can get only 4700 rpms at WOT. The mechanic has verified all is running well and compression, fuel pressure and timing is fine. It starts easily and smooth idles at about 900 rpm. 5000-6000 rpm is supposed to be WOT limits. Any suggestions or comments would be appreciated. Is 4700 rpm close enough? I don't want to go stainless.
  #2
Old June 27th, 2009, 07:57 PM
steelespike steelespike is offline
Default Re: Correct Prop for pontoon boat
Well its obvious you need about 1300 rpm.
If the dealer set you up they should let you try props till they get it right.
I would start with a 9 and see what it gets you.Props are available here down to 7".Some in 4 blade.Rule of thumb 200 rpm per inch But on smaller motors this could be higher.If the 9 puts you well within the rpm range maybe stick with it to try to maintain some speed.
You could try raising the motor a hole, might get you a little rpm.
Also try different trim settings do one thing at a time.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Correct prop on used boat? docoakley01 Prop Questions and Topics 3 June 14th, 2009 10:56 PM
Correct prop on used boat? docoakley01 Prop Questions and Topics 0 June 14th, 2009 09:54 PM
Correct prop for my boat? Dante04SRT Prop Questions and Topics 1 September 4th, 2008 11:36 PM
SS Prop is a waste of $$ on a pontoon, correct? limulus Prop Questions and Topics 5 May 26th, 2008 09:06 AM
Finding correct Prop for a Pontoon boat with 70 horsepower Johnson outboard? Big Bubba Prop Questions and Topics 5 May 24th, 2008 09:16 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
