ive finaly put the boat in the water and ran great ! when i got home i had oil all over the lower unit from the tilt trim down towards the boat side?only on the the lower unit only?is this normal and by the way this site is great !learning alot !
Sounds like you need to have your tilt trim unit rebuilt. With the boat out of the water clean every thing up then raise and lower your motor and see where your leek is.
its not the trim its coming from where the water comes out when running but on opposite side its definitly coming out of lower unit! back side next to boat!
and by back bolt on lower part of the lu!!
