Duckseason
- May 18, 2009
- 17
Well the deck is ripped out the soggy foam gone and the rotted wood. I have glassed 2 spots on the hull and all is well. Should I .....
1.Pressure wash the entire deck since the glass has set up for afew days to get all the junk and dirt out and Mek it before I do the stringers?
2.Once I have the new stringers in I would like to add a coat of resin to the entire deck of the boat for added strength since it is a Vintage 1974 Chrysler Tri Hull and like I said I will be using this to get into some shallow areas for duck hunting on rivers and lakes So I figure it cant hurt.
3.Foam replacement... use the expanding stuff or that water resistant stuff everone has mentioned and I cant remember the name of...
Any other suggestions let me know... please.
Thank you in advance....
