Psychodad7
- Jun 3, 2009
- 4
I just bought a boat with a 1992 Evinrude 40 hp motor. It would not pump water through the telltale with the muffs, so I replaced the waterpump parts12 pc. kit. same result. Put motor in 1/2 barrel of water, Have water coming from the telltale for about 10 seconds then it stops for about the same amount of time, repeats until alarm sounded continous. Shut down let cool to 120 removed thermostat and restarted, same results. Rpm's did not appear to have any affect, also smokes a little from telltale until water flows when first started. Where should I look from here?
