June 27th, 2009, 01:05 AM
1974 115 Evinrude gear ratio/Max rpms
I been researching it and looks like the gear ratio is 2.0 and RPM is anywhere from 5000 to 6000. Anyone with something better than a seloc book?
Thanks!
__________________
1975 Cobia Tradewinds SS-170
Close Bow 17 Footer V-Hull
1975 Evinrude 70573-B 70HP
1968 Babcock
Bow Rider 15 Footer Thrihull
1968 Mercury 500 50 HP
Yes, I could google it, but I rather get advise from my Iboats fellow members...
June 27th, 2009, 01:11 AM
Re: 1974 115 Evinrude gear ratio/Max rps
Nandy, my data shows a 2:1 gear ratio but it shows the RPM at 4,500 to 5,500 at WOT.
H
June 27th, 2009, 01:15 AM
Thanks!
__________________
1968 Babcock
June 27th, 2009, 01:39 AM
Re: 1974 115 Evinrude gear ratio/Max rpms
You are very welcome.
H
June 27th, 2009, 07:41 AM
gear ratio is 2:1 and rpm is listed from the factory as 4500 -5500, but several people believe that they are some what lugging at those speeds and will suggest going to 5600-5800rpm's. I was hesitant at first, but the motor does seem happier at the higher rpm's.
Thread Tools
Search this Thread
Display Modes
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
