  #1
Old June 26th, 2009, 10:57 PM
Ned120 Ned120 is offline
Default What is it part ? Re: 1975 Evinrude 25 hsp
Directly beneath the carb, is a hose nipple for a very narrow inner diameter hose that loops up to the top left of the motor (facing it from the carb) and plugs into another nipple, not well described in the Clymer manual,that is my only source of help, but possibly the exhaust cover. The only vague reference in the manual is to an "outboard water indicator hose" . No idea if that is what this part really is. The old hose was bad and I replaced it with a piece of clear narrow diameter fuel line. Once I got the motor started, it bucked each time a droplet of fluid was pulled up the line by the action of the motor running. What is this hose and what's its function? many thanks for all responses.
  #2
Old June 27th, 2009, 06:36 AM
Chinewalker's Avatar
Chinewalker Chinewalker is offline
Default Re: What is it part ? Re: 1975 Evinrude 25 hsp
It's a recirculation hose. It takes unburned fuel/oil mix from the bottom of the cankcase where it tends to collect and uses crankcase pressure to feed it to the top of the crankcase. This gives a little extra lube to the upper bearing and also helps the motor burn off the extra fuel...
__________________
Share A Project Page for 1971 GW Invader Banchie 13
http://www.shareaproject.com/pages/p...,p,433,00.html
Share A Project Page for 1976 American 18
http://www.shareaproject.com/pages/p...,p,404,00.html
Share A Project Page for 1974 American 15
http://www.shareaproject.com/pages/p...,p,405,00.html
  #3
Old June 27th, 2009, 10:02 AM
F_R F_R is online now
Quote:
Or, possibly he is speaking of the crankcase drain hose, goes to the upper bypass cover. In bygone years, the crankcase drainage was merely dumped overboard. Due to environmental concerns, it was then dumped into the upper cylinder via the bypass cover, where it hopefully gets burned. Sounds noble, but doesn't really burn that well and causes rough idle.
  #4
Old June 27th, 2009, 11:29 AM
Thanks, that nails it pretty well. My theory was that it was something like that. Appreciate the help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Have Question 1975 25 horse evinrude yeagermeister Johnson & Evinrude Outboards 3 May 15th, 2009 05:54 PM
1990 9.9 Evinrude VS 1975 25 Evinrude mikewoller Johnson & Evinrude Outboards 6 May 4th, 2009 06:02 AM
Help Identify Broken Part! 1975 70HP Evinrude mattkenton Johnson & Evinrude Outboards 8 December 29th, 2008 11:36 AM
1975 25 HP Evinrude came in today! jspringator Non-Repair Outboard Discussions 12 October 31st, 2007 09:47 PM
Montgomery Ward 25 Hsp. SkipMoss Other Outboard Brands 6 July 26th, 2004 05:35 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
