Weight-1984 Century
Status
Not open for further replies.
dolphinlvr
I'm trying to find the weight of a 18' Century with an 140 Merc. Cruiser. I need to know if my 6 cyl crossover and class 2 hitch can pull it? Anybody help me, please.
Silvertip
Re: Weight-1984 Century
Without a model -- it's only a guess. My guess is 3000# full gas gear and adult beverages. And whatever you put IN the vehicle counts toward the tow rating. As for your 6 cylinder crossover -- Six cylinder what? And by the way -- double posts on the same issue are really frowned on.
davg
I don't think that should be a problem for you. Check the gross weight in your owners manual for the vehicle. Your boat & trailer are probably around 2300 lbs or so. Boat weight should be on the Manufacturers plate.
Bob_VT
Welcome to iboats.
See the date of this thread? June 2009
Please continue to be an active member here...... threads that are old are just used for reference unless they are re-opened by the original poster.
I will close this one and let it drift back down into the archives.
Status
