I can not find an access panel to disconnect the shift rod. The only access panel I could find is at the bottom of the leg, on the lower unit. I was told this is for adjusting the forward and reverse. Do all Johnson's have an access panel for disconnecting the shift rod? Maybe I am overlooking something?
Thanks
Thanks
