  #1
Old June 24th, 2009, 01:03 PM
JustAnotherBoat's Avatar
JustAnotherBoat JustAnotherBoat is offline
Default Do you tow a tube with your tower?
I am looking at adding a tower but I have noticed that some of the manufactures do not recommend towing an inflatable(tube) with the tower. Is there really that much difference between a tube and a wakeboarder? I feel the boat being pulled harder by the wakeboarder when they cut out than the tube is sliding around back there. I see people doing this everytime I am at the lake, so are they just ignoring the safety guidlines or is there anything really wrong with doing it. I am looking at both buying a tower or having one built from some of the designs of the diyers from this website. http://bierbower.net/diytower/
Would any of these hold up to towing a tube? The tube we use is only a single person anyway.
__________________
Nothing Special just a
88' Chris Craft Cavalier
  #2
Old June 24th, 2009, 01:51 PM
bigpoppakdog bigpoppakdog is offline
Default Re: Do you tow a tube with your tower?
Well, having pulled people on a tube with my 7 ft pylon. The thing I notice is that you can really get that tube to fly. The higher pulling point, gets the tube to skim the water. I have a monster tube that can hold four people and with two kids in it(approx. 230 lbs) I had to be cautious when turning as I could probably have bounced them pretty high in the air. This was the first time I pulled this big monster tube. Plus, I do think pulling a tube does put out more stress than a wakeboarder, especially if you are making those aggressive turns when tubing. So, I would say be cautious on those whip turns, and be carefull if the tube gets to the side of you to not gun it and put strain on your tower.
My 2 cents.
  #3
Old June 24th, 2009, 03:22 PM
IVAZ IVAZ is offline
Master Chief Petty Officer
I don’t think your suppose to tow tubes from the tower due to the risk of capsizing. Wake boarding does not "pull" on the boat thru turns as much as a big tube.
  #4
Old June 24th, 2009, 03:48 PM
Utahboatnut Utahboatnut is offline
Plus if the tube were to ever get submarined which can and does happen and you didn't see it as the driver, the amount of drag created is enough to rip the tower off. I wouldn't even think of pulling tubes from mine but thats just me. Talk to any of the tower mfgs and get there take on it, see what reasons they give and let us know. For me it isn't worth the risk of trashing my boat due to a fluke thing while towing something the tower strictly states not to do.
  #5
Old June 29th, 2009, 06:14 PM
overload overload is offline
We tube off of a tower, a 7' pylon actually, all the time. It also says not to tube behind it on a small warning sticker. I think we were tubing off of it for 5years before we realized that you were not supposed to, so we just kept using it anyway.
  #6
Old July 2nd, 2009, 02:17 PM
Tabes117's Avatar
Tabes117 Tabes117 is offline
I pull my little kids off my tower. I don't like pulling adults, because of the weight and drag.
__________________
2005 Ebbtide 2300, 6.2mpi with bravo 1
  #7
Old July 13th, 2009, 12:51 PM
wall37 wall37 is offline
I pull our tub with Insanity Pylon, works great!
  #8
Old July 13th, 2009, 06:48 PM
salty87 salty87 is offline
no way
  #9
Old July 13th, 2009, 08:46 PM
Showtime22's Avatar
Showtime22 Showtime22 is offline
I wouldn't tube off the tower. Tubes load with water when capsized creating a lot of drag. Most of the time I have ripped a tubes stitching happened when it was upside down.
Also on my boat the tower is not nearly as reinforced as the transom. I haven't heard of anyone tearing off a tower or pylon but I wouldn't feel right hitting the throttle with passengers in the backseat that could catch an aluminum sandwich. Even if they were the in laws.
  #10
Old July 29th, 2009, 11:02 AM
LS1_SE7EN LS1_SE7EN is offline
Last summer I watched a boat towing a tube with one guy on it. The tube hit a bump and flipped upside down. When it landed, it snapped the top of the tower in half. It turned one continuous piece of 2.5" round aluminum into two pieces in one quick snap. I'll just stick to the ski pylon for tubing.
  #11
Old July 29th, 2009, 11:51 PM
Flying Sushi's Avatar
Flying Sushi Flying Sushi is offline
We have a tower but never pull tube with it. They are not designed for toeing tube. We have a Ski Pylon which is an option for latest Four Winns large sport boats. It is about 2’ high and they are designed to work with tube so we use it for tubing and skiing. We use tower for Wakeboarding only.
__________________
Today’s Fish is tonight’s Sushi!
08 Four Winns H260, VP 8.1Gi DP, Huge Bowrider
  #12
Old July 30th, 2009, 02:29 PM
SeanT's Avatar
SeanT SeanT is offline
Are you sure it didn't just break at the hinge point? Nearly every tower I've ever seen has some way of folding down so that boats can still fit in a typical garage.
I'm not saying there wasn't damage done, I just find it very unlikely that a 2" aluminum or steel tube snapped right in the middle when it most likely came apart at a junction or one of the mounts.
__________________
1998 Moomba Outback, Indmar Blackhawk 350ci, 4bbl Holley carb
  #13
Old August 2nd, 2009, 02:24 PM
the break looked porous as if it were at a weld. It was definitely not at a folding point though. It was in the middle of the horizontal section at the top. Looked like a freak accident.
  #14
Old August 3rd, 2009, 12:50 PM
A tube generates substantial more pull than a wakeboarder. 200 lbs on a tube versus 200 lbs on a wakeboard is waaaaaaaaay different.
  #15
Old August 4th, 2009, 03:16 PM
PitchFork's Avatar
PitchFork PitchFork is offline
We pull only wakeboards and kneeboards from the Aerial Tower. Tube gets hooked to the transom hook.
__________________
1994 19' Chaparral 1930SST Bowrider 5.0L 4bbl Rochester
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Can I Tow a Tube From A Ski Pylon? mulv80 Boating, Activities and Destinations 19 September 15th, 2008 01:12 AM
Ataching Tow Rope to Tower SurferBoy Wakeboarding 2 April 25th, 2008 07:36 PM
Pull a tube from tower a70eliminator Wakeboarding 3 January 11th, 2008 12:49 AM
tube tow rope (bungee style) djvan Boat Topics and Questions (not engine topics) 5 December 8th, 2007 08:27 PM
Adding a tow attachment, pylon or tower. recommendations? tmh Boat Restoration and Building 14 September 9th, 2006 11:10 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
