Volvo 275 Gimbal Clearance
rucaradio
Not sure whether I should put this here or not... Mods move if necessary.
Last weekend I got my shiny (and dry) new transom installed. I'm running a AQ131-D with the 275 leg.
When I popped the gimbal off pre-transom fix, I had a width of 2" from inside of the transom to outside of the gelcoat. Now that I've got a bit stronger transom, my thickness is about 2 1/4". Will that be a problem when I reinstall the gimbal? Anyone know the Volvo install tolerances?
