  #1
Old June 24th, 2009, 10:14 AM
kohj1978 kohj1978 is offline
Default new boat with a few questions
i just bought a 1989 capri 1950 with the omc 2.3l, we checked the engine out of the water for leaks and to make sure everything was in working order, and it all seems to be, so we dropped it in the lake and and what a dog, the motor looks new, with no oil leaks or water the temps stayed at 180 on wot the top speed was 35mph trimed with the 13 1/4 x17 prop checked with gps, but it took forever to get on plain, only had 3 ppl in and a half tank of gas. whould i be looking for and engine problem or a prop sizing issue. in the long run i would like to see 45mph. luckly my neihbor is a mechanic so i can have him look at it but it runs perfect, idals smoothsound great. also my tach like to do its own thing so ill be checking that today, im not sure were to start after reading so many threads
  #2
Old June 24th, 2009, 10:22 AM
sea wolf sea wolf is offline
Master Chief Petty Officer
Default Re: new boat with a few questions
Well, the boat is underpowered. A 2.3L on a 19ftr. won't get you on plane quickly. It's as simple as that.
  #3
Old June 24th, 2009, 10:30 AM
i guess i need to look for another motor, theres a large boat salvage yard near me will the 3.0 bolt up to this outdrive
  #4
Old June 24th, 2009, 11:11 AM
mkast mkast is offline
After the tachometer is up and running, WOT rpm is important.
The propeller is sized to limit the maximum rpm of the engine.
WOT specs may be on the valve cover, or go the the adults only thread and download the Mercruiser manual for the engine. Match the propeller to get in the range for WOT.
  #5
ziggy's Avatar
ziggy ziggy is offline
i'd start with a compression test to see if ya got something to work with, then move on to a minor tune up and see where that leads ya before i'd start looking into a repower...
__________________
'Lime Time'
1975 AristoCraft Nineteen
Mercruiser 165hp (chevy 250 L6), 1 drive
  #6
Old June 24th, 2009, 12:11 PM
Dave1251 Dave1251 is offline
The boat is under powered, but it could be something as simple that you are trimed wrong. When you come on plane, trim all the way down. Also you can place some people in the front of the boat. For top speed, trim up.
If you change props size, you can either improve top speed of hole shot. Smaller pitch will improve hole shot, larger pitch will improve top speed. Becareful not to over rev your boat is you change props.
  #7
Old June 24th, 2009, 12:57 PM
okay im going to have a compression test done tonight, i already downloaded the omc book from that section but my motor is the ford so i dont think the the merc one will help. i just tore into the tack the wires had a little corsion so i cleaned them up, right know the tach reads 6500 at wot but itdoesnt even start to work until half throttle, and as far as ive read in other post thats the factory prop size, and i did have it trimmed, (up to recently 6yrs in uscg small boat coxswain BM3) so i can drivem just not fixem
  #8
Old June 24th, 2009, 06:34 PM
fyrfightr fyrfightr is offline
From what I remember(sold those boats back then), the 2.3 liter was only available in the 1750 model. the 1950 model came standard with the 3.0 liter or the optional 5.0 liter. The 1950 with the 3.0 were dogs, slow to plane and a top speed in the mid 30s. I would assume that someone has replaced original engine with the 2.3.
  #9
Old June 25th, 2009, 10:39 PM
ive looked around and found several other 1950s with 2.3, bayliners crule joke i guess. i fixed the tach so im heading out in the morning for some test runs im also bring some other porps to test i found that wot should be 5200 to 5600rpm. now im think of getting some smart tabs and and a new cuped prop and ill do the motor over the winter i post the runs later
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
New Boat, and some questions Hunter1st Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 June 6th, 2009 11:07 PM
questions about new boat joho5 Boat Restoration and Building 3 April 17th, 2009 10:11 AM
New boat questions ferrariman Boat Topics and Questions (not engine topics) 6 March 19th, 2006 09:30 AM
New boat questions wormgear Boat Topics and Questions (not engine topics) 1 April 1st, 2005 01:04 PM
New boat questions????? masterp Boat Topics and Questions (not engine topics) 24 January 13th, 2003 03:50 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
