I have a 1972 Evinrude 85hp serial#85293R Hydro Electric Shift that will not come out of forward gear. After reading this forum I have tried to jump wire 12V across from the starter solenoid to the green wire coming from the solenoid in the lower unit. I get nothing the man I got it from told me to remove the plugs, turn key one click push the button to neutral and rock the prop back and foth untill it comes out???
The starter will engage the flywheel but will not turn it, it is like it is locked up but have check and can't fine anything. Change the oil in the lower unit to Type C to make sure that had nothing to do with it.
Guys I have to say after reading this forum you guys have been a great HELP Thanks very much alot of good information here.
