Trim locked up
I have a sunbird with 2.3 Ford I have been putting gaskets on now foot won't go down . All it does is click is anyone got any suggestions on what to do next . I bought a new boat this one needs to find a home.
PINESOL
Re: Trim locked up
welcome aboard! more info needed, what year and drive do you have ? could be a bad or corroded ground .
lclack
Re: Trim locked up
We also have the same boat. It is a 1990 sunbird skeeter. the starter had to be replaced today and once it was put in, the trim will not go up or down. It doesn't click or anything. Does nothing. Was working before the starter was put on. Disconnected the battery but it is connected back now and still won't go down. Any suggestions?
Howard Sterndrive
Re: Trim locked up
aside from starting your own thread (instead of tagging on a 3 year old one), I would suggest following the heavy cable (red/purple) back from the trim relay supply to the starter and maybe attach it to the starter where it was left off at reassembly, possibly.
or check the 50A inline fuse (black barrel shaped fuse holder along the same heavy wire the starter to the tilt relays)
