I bought a 1986 capri bayliner with an 85 HP Force engine. The head gasket was blown and the carbs were a mess. There was also a problem with the fuel pump but I got everything fixed and actually got the boat in the water last season.
I followed the mechanics recommendation on storing the engine. I had had the boat in the water several times this year and the engine runs OK but I am having two issues that I think are related.
1. When idling after the engine is warmed up I try to maneuver around the boat launch but the engine keeps dying .
2. When I have been operating at Full throttle and slow down to an idle, when I try to go back to full throttle the engine bogs down.
I think both have to do with fuel starvation but when I try to tune up the idle mixture to solve a problem with the idle the SELOC manual doesn't show the location of the idle mixture adjustment screws. I wonder if it is located through the air intake but I don't want to screw up the settings.
I had the carbs cleaned late last season and followed the mechanics recommendation on storing the engine. I had had the boat in the water several times this year and the engine runs OK
