screwonbudnik20
- May 24, 2009
- 8
Model VE200SLESE 1990 year model. Engine is a little rough to idle. When throttle is advanced seems to be choking out. But if you hold the primer in the whole time, it will quickly get on plane and turn over 6000 rpm on its way to 70mph. So that being said it tells me the ignition system is fine. The motor sounds very good. It seems I have a fuel delievery problem. When looking at the carbs with the silencer off, when going WOT it seems the fuel does not have enough pressure coming out of the high speed jets, but when you hit the primer there is a noticeable increase in fuel coming from the high speed jets the pattern becomes more of a fan shape in comparison to without the primer engaged. I completly dissassembled the VRO last night it did not appear to have any problems. It has a new fuel filter. Also new fuel line from the bulb to the VRO, as last night found leak in line just past the bulb. Please help me in the right direction.
