  #1
Old June 22nd, 2009, 03:34 PM
4thekids 4thekids is offline
Default 90HP Mariner No Power at full Throttle
92 Mariner 90 Hp Outboard, Starts and runs slow just fine, When Throttle is put to full, it seem to lose a cylinder (Bottom cylnder of the 3 cylinders). If only 1 person is in the boat, It will start acellerating slowly then like a switch it kicks in with no problem after about 1 minute and runs fine until brought back to an idle, then the same happens. If there are more people in the boat or pulling a tube, it will not kick in. All spark plugs are OK, the coils check out with a ohm meter OK. $$ are very tight so need a good diagnosis to repair. Is it the CDI, or what is a trigger? or could it still be a coil even though they all check out the same?
  #2
Old June 22nd, 2009, 05:09 PM
sylvaing sylvaing is offline
Default Re: 90HP Mariner No Power at full Throttle
I had the exact same problem last year.
I ended up changing the switchbox, trigger, stator and voltage regulator. IIRC, some parts have been modified in a way that other parts needs to be changed as well. I think that was the case for the stator and the trigger.
I think it ended up costing me around $500. The engine has never been run as smooth as it is now since I got it.
See thread
http://forums.iboats.com/showthread....59#post1780459
Edit: Get the manual for your engine from this thread:
http://forums.iboats.com/showthread.php?t=309079
Should help you diagnosing the problem...
Last edited by sylvaing : June 22nd, 2009 at 05:26 PM. Reason: Found link to the engine manual
  #3
Old June 23rd, 2009, 03:52 PM
Thank you Sylvaing.
Now the update, all 3 coils have been checked out the same. The Stator was replaced 8 years ago with the voltage regulator. Checked the Stator, and all resistance readings are good per the spec.
Being it is the same cylinder droping (always the bottom cylinder) and the coils interchanged with the same result. Would the problem be more specific to the switch box?
Does the switch box control weather the engine runs on 2 or 3 cylinders?
Thank You.
  #4
Old June 23rd, 2009, 11:27 PM
Found this link that might be of some help to you...
http://www.marinepartsman.com/ELECTR...outboards.html
Specially :
"OUTBOARD ELECTRICAL & IGNITION TROUBLESHOOTING TIPS
1. Intermittent, weak, or no spark output at two spark plugs usually indicates a bad TRIGGER.
2. Intermittent, weak, or no spark output at all three spark plugs usually indicates a bad STATOR or SWITCH BOX.
3. Intermittent, weak, or no spark at any one spark plug usually indicates a bad SPARK PLUG, COIL, or SWITCH BOX."
So since you ruled out the plugs and the coils and only happens to one cylinder, this leaves the switch box like you said.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
yamaha 90hp full throttle problem case1 Yamaha & Suzuki Outboards 4 February 11th, 2009 04:55 PM
9.9 Mariner - power loss at full throttle WallyMaster Mercury & Mariner Outboards 3 August 26th, 2008 10:29 PM
Mariner 8hp lose power on full throttle Superflid Mercury & Mariner Outboards 7 December 24th, 2007 11:20 AM
86' 90hp Power loss at full throttle after 5mins imported_Rosey Johnson & Evinrude Outboards 3 November 23rd, 2006 06:29 PM
No power at full throttle on 82 Mariner 60HP JermBos Mercury & Mariner Outboards 3 October 4th, 2005 06:50 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
