ARCHSEA BUNKER
- Mar 6, 2009
- 50
Put New Tank In Boat, All New Lines And Vent, All New Filters, Racor Vst And One On Motor, Had All The Injectors Serviced, Motor Ran Sweet 5700 Rpm No Problem, Put About 75 Gallons Of Fuel Through System. Then Today Motor Stalls I Squeeze The Bulb Get The Motor Going Limp Home Squeezing The Bulb Am I Looking At A Fuel Pump. The Bulb Was Not Collasped, Low Pressur Fuel Pumps Changed Last Year. When I Start Motor After Priming With Bulb And Disconect The Fuel Line I Dont Feel Any Suction, Do I Need A Special Fuel Pressur Gauge, Would The Pump Go This Quick Without Warning, I Had Fuel Water Issues With The Old Tank. Checked Vent, Whats My Next Step, Fuel Pressur Procedure. I Know This Is Not A Cheap Item So I Want To Be Sure Thank You WHAT SHOULD BE MY PRESSUR READING
