  #1
Old June 22nd, 2009, 12:54 AM
boatsmith boatsmith is offline
Default Mariner 40 Starts then Dies After a Short Run
When I first start my Mariner 40 (S/N OG402756, 1996 C40 ELPTO), on the trailer with the water ears on, I use the choke. It starts, I rev it with the neutral throttle lever and after 5 - 15 seconds, it dies. If I push in the choke button before it begins to stumble, it will recover for 5 seconds before I have to push the choke again. I have checked timing, checked synchronization of throttles, cleaned the carbs, replaced the fuel pump diaphram and used a new tank, fuel line and fresh fuel. A previous owner replaced the reed valves to correct a problem about 3 years ago. A previous owner also removed the oil injection system. This is a 4 cyl model with 2 carbs. Please help with any ideas of what to check out that may cause this. Is there any reason to believe it might perform better in the water at the dock?
  #2
Old June 22nd, 2009, 01:08 AM
j_martin j_martin is offline
Default Re: Mariner 40 Starts then Dies After a Short Run
Quote:
What happens to the primer bulb? What happens if you pump the primer bulb when it balks?
Could be an air leak, or plugged fuel line, or plugged gas tank vent. Answering the questions will help pin it down.
hope it helps
John
  #3
Old June 27th, 2009, 03:40 PM
If I pump the primer bulb it makes no difference. The bulb will pump up very slightly after engine runs for a time but the engine doesn't respond. I am cleaning the carbureators and found that the bottom carb has a main jet stuck in the threads. This is the approx 1/8"-3/16" threaded brass jet that screws into the middle of the venturi from the bottom up. I cleaned that carb with spray Chem-Tool since I could not remove the jet and plastic venturi tube. It seems to have good spray through all ports. I'll replace it and try to run. If anyone has a used bottom carb in mint condition, I would like to buy it. The carb nos are
WMA 2
3330-830281C
13-3
0436
Engine S/N OG402756 - Mariner 40 HP, 4 cyl, 2 carbs, 1996
Be sure the jet threads are clean and jet screws out OK.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1982 mariner 15hp starts for a few seconds then dies tomisty05 Mercury & Mariner Outboards 10 May 27th, 2009 11:32 PM
Merc 40 HP EFI 4Strk 2005 starts and dies Delta Mark Mercury & Mariner Outboards 0 May 20th, 2009 06:14 PM
87 evinrude 40 hp starts and dies musky55303 Johnson & Evinrude Outboards 1 June 6th, 2007 09:11 PM
Starts but will only run for a short time.... imported_Chris R Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 July 13th, 2006 11:18 PM
69/74 merc 40 (4hp) starts once but won't run fishurman Mercury & Mariner Outboards 2 August 4th, 2003 10:25 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
