Re: 1968 55 hp Evinrude cooling
Rodneys, thank you for the breakdown. I understand that there is no by-pass stream, tell tail or pee stream that lets you know that the water pump is operating. What I'm trying to say is: where does the water that has cooled the engine exit? Is it from the prop hub with the exhaust or does it come out somewhere else, keeping in mind this water should be relatively warm when it exits. Again, thankyou for the breakdown link and info.
