I read several threads on a no spark issue and have a couple questions. I had no spark on any cylinders. So reading through I checked the stator and found an open circuit on the blue to ground and assumed it bad. Ordered a replacment from CDI. They say to install it to match th old one. I pulled the original stator (Merc type) and it is different then the new CDI. I orieented it to match the old merc stator that being the wires leading away from the stator in the same location as the old stator. Is this correct? If so I still have no spark. Raeding aghain I disconnected the blk/ylw from each switch box and tried with no spark and then disconnected the yellow wires from the stator with no spark. It talks of getting DVA readings I have a multi meter with a MAx hold feature which holds the maximum reading. Am I correct testing the red to ground and the red/white to ground should be getting 30volts and blue to ground and blue/white to ground 1801volts? I dont get either the most i see is 3 volts on blues and a fraction of a volt on red. Any thoughts?
