Re: Mercruiser 140 Hard Started and Idler question
Hi, still having problems. I took it on a fishing trip for five days. It always started hard. It runs on the starter till about 800 rpm then I can finally get it going. I usually run the battery down to get it to start. When started it only runs good around 1200 rpm. I know the linkage is out on the shift interrupt switch. It doesn't stop the engine to shift, but I know the switch works cause i can manually move it to kill the engine. The boat will sometimes run up to 2000 rpm on idle. When it runs that high I can turn the ignition off then back on again after about a second. The rpms drop and will stay around 1200 rpm. Then they will slowly rise sometimes. I know thats a little bit of linkage issues. But the boat shouldn't start running on lower rpm when I turn the key off and on again. Could this possibly just the carb is worn out. I did rebuild it. It runs great at above 1000 rpm. Its has lots of power and runs good full out. I even ran premium gas in it. Can it be a week coil. That boat use to start and run good. The last 4 years has been giving me problems. I did the points, condencer, wires, rotor, cap, plugs, carb kit. I don't know what else to do. I really don't want to take it in because the bill will higher than what the boat is worth. I figure I'm a handy guy with engines, but this thing is killing me. Its a 140 mercruiser 4 cyc. 2 barrel carb. How much will timing affect the starting. I never checked it this yesr but it runs good other than starting and idle. I just have to keep it idling higher but thats hard on the gears when shifting. Any more help would be welcome. I'm ready to sink it. Thanks
