'94 Mercury 90 HP outboard won't start
Kekoa
I have a 1994 Mercury 90hp outboard electric start motor that won't start anymore. I checked the voltage with a meter, and it seems that there is power everywhere up to the coils, but there is no power going from the coils to the plugs. I am not getting any spark. The funny thing is that since I first noticed the issue, it started a couple of times, and then wouldn't, then would, then wouldn't, and now it doesn't. I read some other posts, and checked the ground wire connections, and they seem clean. Could it be the switch box? I wanted to see if there was anything else to check before spending almost $300.00 for the switch box.
jjacobs007
Re: '94 Mercury 90 HP outboard won't start
have a kill switch?check that maybe shorting out.Or neautral safety switch!
Kekoa
The kill switch seems to be okay. What should I check next?
Scott
airframer
Check for corrosion at connections or loose wires
Kekoa
The connections are clean, no corrosion. They look pretty shiny under the black protectant stuff that they put on the connections. The big fuse is still good also. When I disconnect the fuse, nothing happens when I turn the key, then when I stick it back together, the motor cranks, but still no spark in any of the plugs. Is there anything else it could be besides the switch box?
By the way, thanks for your replies.
electricjohn
Someone recently posted a sequence of test to do on the ignition system for a 'no start' condition. Try a search.
jjacobs007
check the no start in gear switch.
Kekoa
Where would the no start in gear switch be?
jjacobs007
i believe in the throttle control box.
