PitchFork
- May 28, 2009
- 313
I have flat spots in acceleration when I accelerate from 2K+ RPMS to WOT. I have no problems accelerating from idle or 1,800 RPM to WOT in or out of gear. The boat is a 1994 19? Chaparral Bow Rider with a GM 5.0LX engine 4bbl. The carb Rochester QuadraJet purchased Nov 2008 from I-5. I have replaced the coil, plugs (gapped at 0.035?), wires, cleaned arrestor, fuel pump, rotor & cap, both fuel filters, and changed the oil. I had the flat spot before I changed all of this and I am still getting a flat spot in acceleration. The choke is almost closed 3/16? from Horn Wall when starting and the boat starts fine with a few pumps of the throttle and with the throttle at half open. The boat starts fine and warms up within 5 minutes and the choke fully opens. I can obtain WOT and boat runs within spec 4600 RPM at 45MPH. The accelerator pump is squirting fuel in both sides of the 4bbl carb at good stream. With the boat in the garage I can pump the accelerator pump a few times and fuel is squirted around the 4th or 5th time it empties the fuel bowl.
I can steady up the throttle to WOT with no problems. I also can pump the throttle to WOT with no problems while in idle. The problems occurs under load i.e. in the water in gear moving at 2K+ RPMs. Idle mixture screws out 1-1/2 turns. Pretty smooth idle. Plugs looks good slightly tan in color. I recheck plugs wires to make sure they were on correctly. Prop is 14 x 19 Mercury Marine Tempest SS.
I have not checked the anti-siphon valve (replaced 2 years ago) at the fuel tank or the pickup screen in the tank.
Any help would be greatly appreciated,
Greg
Greg
