Have searched but not found something similar.
1986 modell
140 HP
Engine # A509730
Starting problem and found water in cylinder # 1 (First from front)
Could this be cylinder head gasket?
No water on dip stick
Manifold and engine drained down for water.
Compression is higher on this cylinder, then the others, measured on cold engine, problem to blow all water out of cylinder.
Removed end cover on manifold, looks fine inside.
Think water intrusion is in cylinder head...
Any advice?
How long time to dismantle cylinder head?
1986 modell
140 HP
Engine # A509730
Any advice?
