  #1
Old June 20th, 2009, 09:04 PM
capt-pete capt-pete is offline
Unhappy my new boat, fiberglass, crack on bow!
(1978 Thundercraft trihull) So, after our fifth outing on the new boat today, I decide it is finally time to put a little elbow grease into a good washing, and up front on the port side, i notice a crack. Never saw it before, since it is a little further down (probably right above water level at planing out) -- it is about 4 inches long, and i can push on it with my finger and it feels a little soft. Also feels like I could peel it back if I pried on it much. I havent pushed really hard on it, as I am afraid I might push a hole all the way through? (How thick are these hulls, anyway?)
I know NOTHING about fiberglass repair, or how to tell if fiberglass hulls can go rotten? When on the water, she feels like a rubbermaid lid when sledding though, but I figured it was just the floor, the stringers still feel REALLY solid.
Could I go and buy a keel shield, and just cover this crack until winter, when I can get someone to do some fiberglass repair? How can i tell if this hull is just toast? There also appears to be some damage under the hull, where maybe someone hit a stump, but it appears to be superficial and runs all he way from windshield level to the end, but it doesnt feel soft there, like it does up front.
thanks for any advice. I hope I havent bought a big problem.
-pete
  #2
Old June 20th, 2009, 10:04 PM
Nandy's Avatar
Nandy Nandy is offline
Default Re: my new boat, fiberglass, crack on bow!
Hard to tell you much without photos. Fiberglass does not rot. The wood covered under the fiberglass does. Find a body shop that does fiberglass and let them do an estimate. Take it to 2 or 3 places and they will tell you how bad it really is. A hole below the waterline is no joke. You can sink your boat easily. To me it sounds like someone tried a repair but is there is no telling. Again, I urge you to take it to check, it might be something that can wait or it could be something serious.
__________________
1975 Cobia Tradewinds SS-170
Close Bow 17 Footer V-Hull
1975 Evinrude 70573-B 70HP
1968 Babcock
Bow Rider 15 Footer Thrihull
1968 Mercury 500 50 HP
Yes, I could google it, but I rather get advise from my Iboats fellow members...
  #3
Old June 21st, 2009, 12:53 AM
Thanks for the reply. I wouldn't say it's taking in a TON of water, just have to hit the bilge pump every 30 minutes or so for about 15 seconds... and that's in choppy water cruising at about 30 mph. It does take on more if I really get to plowing through turns and driving hard.... and it is technically a hole, but more of a crack or split... not sure if it goes all the way through. I would take a picture, but my digital camera has not battery power, and we cant find the charger. (Ain't life grand?)
I bought a little sand paper and some "waterweld" to hopefully get through tomorrow, and then next week I will take it to a repair shop to get an estimate on fixing the hull throughout...
Any ideas on what the going rate for fiberglass work is?
  #4
Old June 21st, 2009, 01:14 AM
Nandy's Avatar
About $25 an hour. By your description you are prob looking at 8 to 16 hours of glass work. I'm done some glass work but I'm no expert. If they have to remove the upper half of your boat then it will be more.
__________________
1968 Babcock
  #5
Old June 21st, 2009, 01:43 AM
Oh, well if it's 400 max to fix the hull, I am cool with that. If it's 400 to fix that one spot HOLY COW.
I put the waterweld in there and will sand it smooth in about 30 minutes. It seemed to go up into the area very well, and so far, seems to have set okay.. If that temporary fix will do for tomorrow, I will just have the hull re-done next week and be out on the water again in no time (I hope) -- I don't have a lot into this boat yet, but sure do like it.
  #6
Old June 21st, 2009, 01:46 AM
Bob_VT's Avatar
Bob_VT Bob_VT is offline
I will slide this into the restoration section. The serious problem is what is getting wet .... such as the flotation. Water intrusion into fiberglass is not good either.
You really should snap a few photos and we have some pro's that frequent the resto section. You will get some advice that is priceless.
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
  #7
Old June 21st, 2009, 02:07 AM
this img is huge, but confirms that the crack was there when I bought the boat.. It is halfway between the Roller on the fron of the trailer and the alabama registration sticker where the brown and the white parts of the hull meet. You can just see it in the brown, and it runs down about 3 inches. I am not freaked out as bad now, as the water I am taking on is manageable.
See how the hull on the bottom is delaminating though? Do I need to look for a new hull, or can this be repaired? It looks like it was either beached hard, or hit a stump, as this runs almost to the end of the back of the boat. It doesnt feel soft there, just like 1mm has been shaved off of the hull along with all of the color.
Sorry for the awful pics. no camera, and I know NOTHING about fiberglass.
The crack somewhat reminds me of what happens to a 1978 Corvette's nose when it hits a curb. (Both are fiberglass, I know) but it seems like a clean break or gash. It's filled with Waterweld now, until I can take it into the shop
Last edited by capt-pete : June 21st, 2009 at 02:13 AM. Reason: getting rid of massive pic
  #8
Old June 21st, 2009, 02:28 AM
Bob_VT's Avatar
I think what you have described is close to this thread http://forums.iboats.com/showthread....t=keel+gelcoat
__________________
  #9
Old June 21st, 2009, 05:23 PM
Well, the patch didn't make it a whole day... but it does appear that it is above the water line for the most part. So, as far as I am concerned, JB Waterweld is not a good product to patch holes or cracks in fiberglass hulls, when the hull flexes, the weld loses its grip and you just have a big flake. I will look into the Marine-Tex solution this week, but it looks like I am going to need some significant hull repairs soon. It's manageable for now, but I assume these things only worsen with time. Looks like I take on a gallon or so every 20 minutes.
On a plus note, the boat ran nice.
  #10
Old June 21st, 2009, 06:08 PM
Bob_VT's Avatar
That hole will need to be ground out and repaired from both sides with fiberglass cloth and resin. Marine tex is not flexible and will give the same band aid result.
__________________
  #11
Old June 21st, 2009, 07:52 PM
jonesg jonesg is offline
shouldn't be flexin where its flexin to do that, if its a bow rider pull the front seats and power sand the hull inside, a good strong glass patch might do it.
Once it stops flexing you can do the outside.
__________________
I don't read private messages.
Get the genuine factory service manual.
www.outboardbooks.com
www.marineengines.com
  #12
Old June 22nd, 2009, 04:43 PM
Yacht Dr. Yacht Dr. is offline
Hello Pete...
Can you get to the inside at all ? You NEED to do inside lams on the inside below the waterline.. you Should do them above on hull.. you can get away just outside lams on the deck
If cosmetics are not an issue..then take a small grinder and get some of that dead glass off on the outside. Patch the spot with some resin and glass ( mat will do fine m8 ). From the looks of it you will have about a 2"x6" repair so sand and paint.
The other hull repairs.. can you get some pics on those ?
YD.
  #13
Old June 23rd, 2009, 11:58 PM
sorry for the terrible quality, it's dark outside and digital camera is dead. I pulled these screenshots off of my wife's flip video camera.
I will also post a link to vids of these issues, might be easier to see that way. Anyway, the top 2 pics are of the bottom of the hull. Looks like the gelcoat(?) is coming off... but the hull there seems REALLY thick and solid. The bottom pic is of the cracked area where I tried the jb waterweld patch, and what it looks like now that it has come off part-way and after I had sanded to apply it. You might not be able to tell, but that's fiberglass cloth you can see there.. I bought a fiberglass kit. I might try sanding all around that pplace and applying resin and another layer of cloth or two, and then sanding it smooth, if I can. Never worked with fiberglass before.
I'll find a place to host the vids and post a link in a separate post.
  #14
Old June 24th, 2009, 12:10 AM
Video of crack (now hole)
  #15
Old June 24th, 2009, 12:14 AM
1st vid of gelcoat(?) damage
Oh, and it doesnt look like I will be able to get to the inside of the hull without taking out the floor. The seats on the bow are atop fiberglass that all looks like one piece that would come off if I removed the trim, rivets, and separated the top from the bottom half.
Probably should have looked at more boats, but she runs GREAT, and for some reason, well, i just wanted this one.
  #16
Old June 24th, 2009, 12:26 AM
Last video underneath boat
With some attention I hope this can all be repaired.
  #17
Old June 24th, 2009, 01:30 AM
I'd take my sawzall and cut the seats out, it has to be done from inside, the seat molding can be glassed back and concealed later.
Either that or pop the cap,
but I like my sawzall.
I guarentee you'll have spent more time hemmin and hawin than it'll take to do it in the end. Just seems to work that way the first time.
__________________
  #18
Old June 24th, 2009, 10:47 AM
Nandy's Avatar
Or,
If you don't care about aesthetics fix it from the outside.
__________________
1968 Babcock
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Fiberglass crack kthkollar Boat Restoration and Building 9 May 26th, 2009 04:06 AM
crack in bow of aluminum boat sasanm Boat Restoration and Building 6 April 16th, 2008 05:22 PM
HELP! crack in stringer on new boat iwhitevt Boat Topics and Questions (not engine topics) 6 February 18th, 2008 08:13 PM
any one ever have there fiberglass hull crack after new stringers bigbad4cyl Boat Restoration and Building 9 June 9th, 2005 08:07 PM
Crack in New Boat NCOffSeason Boat Topics and Questions (not engine topics) 8 October 28th, 2003 04:21 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
