Hi all, I recently bought a 1974 70 hp johnson. Compresion was 128 104 and 128. I think the rings may be stuck on the one cylinder so I believe all is fine there.
I put a new water pump in and it pumps water like crazy.
The motor fires right up first try everytime, But doesnt want to run on all 3 cylinders when under power. As far as I can tell number 1 cylinder fires intermitantly.and same for number 3.
I'm looking for any suggestions or help you all could offer,I have not worked on outboard motors alot and im sure there are some patterns to these old motors.
My first guess would be high speed jets right? I am taking carbs off now to clean but please offer your 2 cents as to what my prob may be.
Should I run a tank of gas through this thing before I start to work on it.I have no clue when the last time it was actually used.
Thanks guys
Thanks guys
