paul bacon
- May 27, 2009
- 5
well i got a 1982 johnson 115, and recently the tach quit working, i used a meter to check everything thing, there is a good ground, good power, and the pulse wire seems to be getting a signal from the motor according to my volt meter. so next i checked the voltage at my battery which was 12.50 volts and then when its running its at 12.45 volts, is that normal? is the rectifier starting to go and thats why the tach quit? seems to me that when the motor is running it should be charging somewhere around 13.50 volts.
