gunner1
- May 13, 2006
- 375
So, I've decided that this spring/summer the transon will get done. I have a 1965 Starcraft and the question I have is this- How do I remove the "drain holes" in the splashwell? I would just remove the transom with them attached, but there's a circular lip around the entire outside of the insert that sits on top of the transom's sheetmetal. Do I need to grind that lip off first? Also- when I remove the motor should I disconnect the wiring harness from the inside of the control box?
