mercury classic 50 question.
Caveman239
started re-wiring a classic 50, 1989 I believe (s/n AO996542) and in the rats nest of wiring there is a black rubber tube 1/4 to 3/8 O.D. running from the front of the lower unit up to the console but its not attached to anything and I cant find anything it could attach to. hoping someone could tell me what it's for. looks to me like a automotive vacuum hose? One more and I'll stop- there is a 0-15 PSI gauge that has (4) wires on it. blue goes to other gauges, black goes to ground on other gauges, then theres a black and white wire that have been cut. Wondering if anyone could tell me what the white wire hooks to?
CharlieB
Re: mercury classic 50 question.
The little hose from the gearcase is used for water pressure at speed to register the speedo.
A 0 to 15 psi guage may have been aftermarket water pressure for the engine cooling. See if there is any additional wiring alongside the wiring harness to the motor and a pressure sending unit on the motor.
