gas/oil ratio for 56 30 hp bigtwin
CATransplant
Re: gas/oil ratio for 56 30 hp bigtwin
24:1, without question. Don't listen to anyone who suggests 50:1.
litymaspf
would you happen to kow the spark pllug gap? I bought some new J6c champions i am pretty sure that is wha it takes.
wbeaton
I've seen a number of posts that suggest 20:1 as the correct mix for that vintage.
Its 24:1. At least, that's what OMC built it to run on.
Plug gap is .030"
Coils of that vintage are always bad even if they spark. Check them when you clean and set the point gap (.020").
R.Johnson
wbeaton: That would be 30# non- detergent, and leaded gasoline. I wonder what OMC did to a roller bearing that it needed only half as much oil.
